Sponsored by: CARiD
Freelander mk1 stalling issues.
Old Dec 23, 2016 | 04:04 AM
Kieran Anders's Avatar
Default Freelander mk1 stalling issues.
I have an 04 plate freelander with the 1.8 petrol engine, It is starting ok, but revs are jumping up and down as soon as I touch the gas. It stalls a couple of times shortly after start when the revs jump down too far
I recently had the upgraded HG and cam belt fitted, (before it failed) including filters, oil and fluids and it was running fine until then. When I got it back this happened. It seems to be much better when it's warmed up. I have changed the Idle control valve and Manifold pressure switch, (only the manifold pressure switch lit up as a fault when scanned)which has improved the issue slightly.
Any idea?
Totally not a mechanic at all but would like some ideas to run past the mechanic.
Cheers!
Gordw
Oct 19, 2013 05:52 AM
weaver01
Jun 6, 2012 09:47 AM
Timebus
Feb 17, 2011 10:10 AM
joverrover
Oct 15, 2010 06:32 PM
brad
Jan 2, 2005 10:12 AM
