Sponsored by: CARiD
front driveshaft info
Old Sep 29, 2006 | 01:29 AM
jusspasd's Avatar
5th Gear
Default front driveshaft info
I have a 01 disco II I took it to the land rover dealership because it was vibrating while I was driving. The mechanic said my front driveshaft was going out and the cause of the problem was while I’m driving the water from the a\c discharges and hits the front driveshaft and eventually will cause damage and need to be replaced. Just some info sorry if this has already been talked about.
Old Sep 29, 2006 | 11:51 AM
Default RE: front driveshaft info
Well the mechanic was part righ and part full of S--T.
Disco 2's are know to have front drive line problems, not because of A/C water dripping on them but because Rover did not put any grease fittings on the 2 u-joints in the constant velocity joint , which is the one that hooks to the t/case.
So stop driving it, pull out the front drive shaft and have it rebuilt , installing new u-joints in the housing and you will be set.
It will cost you about$150 which will be alot less then what Rover quoted you. By the way, if you let it go and it breaks, which it will, you will also be replacing the transmission and or t/case at the same time so do it ASAP.
Any questions, get back to me.
Mike
Old Sep 29, 2006 | 04:15 PM
jusspasd's Avatar
5th Gear
Thanks for the reply DiscoMike..guess u were right he was full of it, because he said I had to buy a new one. repair work was going to be 1065.00. I called PEP BOYS they said they could rebuild it( they didn't quote me price so hopefully they can) Thanks again.
Old Sep 29, 2006 | 05:47 PM
Be careful with Who ever you take it to, make sure they install HD quality u-joints with grease fittings and make sure they have done constant velocity joints before.
Are you going to take it off and take it to them< it will save you some money?
Plan on the u-joints running about $30 or so a piece and around $100 in labor.
Mike
Old Oct 2, 2006 | 01:15 PM
jusspasd's Avatar
5th Gear
I’m going to take it off myself. I always try to save as much on labor cost as I can.
robert.juric
Nov 3, 2022 06:08 PM
AaronG
Apr 1, 2012 08:00 PM
DISCOVERY182
Mar 22, 2012 08:49 AM
clandrovers
Oct 10, 2010 01:09 PM
98roverguy
Nov 16, 2006 06:30 PM
