Sponsored by: CARiD
Fuel Issues
Old Dec 16, 2017 | 06:10 PM
smardiswv's Avatar
Default Fuel Issues
I have a 2004 Range Rover with 130k. I am having problems with the vehicle acting like it is starving for fuel. I changed the fuel filter and I run no less than 91 gas in the vehicle. I am trying to trouble shoot. Should I look to the fuel pump next or are there other items I should look at first? I would appreciate some guidance. I am not a mechanic at all but I am trying to save myself a ton in repair bills.
Thank you
Old Dec 16, 2017 | 09:46 PM
XCELLER8's Avatar
when exactly is it starving? ....does it idle ok , cuts out on acceleration ?...get a fuel pressure gauge and see what you are getting ....you should be in the mid 30's for pressure
Old Dec 17, 2017 | 04:29 AM
smardiswv's Avatar
Default Xceller8
Thank you for responding. The vehicle idles fine and revs fine. The cut out happens in acceleration, specifically when I am going up a hill and turning to the right then left, like through an S turn.
Alex Spencer
Apr 20, 2017 07:48 AM
JumPeR04
Apr 7, 2011 09:52 PM
musickjr
Jun 21, 2010 07:44 PM
rj95lss
Jan 4, 2010 01:09 PM
Morgan
Aug 14, 2007 08:15 PM
