Sponsored by: CARiD
Fuel Pump issue in '98 disco
Old May 27, 2013 | 02:45 PM
kevinhaughton's Avatar
Default Fuel Pump issue in '98 disco
Any advice would be wonderful thank you.
My '98 Disco stopped suddenly one day. I could not here the fuel pump running when advancing the key so I 'rapped' the pump module and it started back up again.
I decided to replace the motor. I was told that the 3270 was a good fit however they had none in stock so I replaced with the following:
DPH (Delphi) FE0115 motor.
and
DPH (Delphi) FS0007 strainer /sock
It fit perfectly. Installed fired it up (after checking to here motor running ok). It took a few cranks but it then ran. Now it seems to be sluggish when advancing throttle through 2000 rpm and it sometimes won't start right away after sitting for a period.
Did I put a lower value GPM motor in or is it losing prime?---please help.
Kevin
Old May 27, 2013 | 04:19 PM
I would first replace the fuel filter then do a fuel pressure test to confirm if that new motor is adequate for your truck.
Old May 27, 2013 | 08:05 PM
32-34 PSI would be expected. Any pix of the work?
Old Jun 6, 2013 | 02:22 AM
james103's Avatar
Old Jun 6, 2013 | 07:43 AM
And the fuel pressure is? Measure at that "tire valve" sticking out of the injector rail on passenger side. Does it "leak down" quickly after pump switched off? Some owners get around a minor leak or weak pump by "priming" - turn key on, hear pump run, then repeat several times. On final "prime" they actually turn key far enough to crank the truck.
Old Jun 6, 2013 | 11:28 PM
sorry was off line with my daughter being sick. i will check the pressure and let you know...thank you again.
K
Travelor
Sep 24, 2015 06:11 PM
thepaleowolf
May 16, 2012 09:47 PM
Jbrovers
Nov 27, 2011 10:00 AM
JumPeR04
Apr 7, 2011 09:52 PM
JumPeR04
Apr 1, 2011 04:15 PM
