Sponsored by: CARiD
Grind me a pound!
Old Apr 13, 2009 | 12:36 PM
timothybryder's Avatar
Red face Grind me a pound!
I have a 74 SWB Series III with a Series II Transmission (Crash Box). I can not get enough clutch to change gears. I have owned a 110, and 3 Series III 109's but I have never worked on this type of gear box. I have adjusted everything I can find to adjust or bleed. Any one have one of these transmissions?
Old Apr 13, 2009 | 12:42 PM
antichrist's Avatar
Have you verified your MC is good? Clamp off the flex hose to the SC, you should have rock hard pedal. If not, you have air in it, or a leak.
How old is the flex line? They swell internally (especially if the the wrong brake fluid was used) and instead of operating the SC, the MC just causes the swelling in the line to go down.
Old Apr 14, 2009 | 05:12 AM
Default Antichrist
Very helpful I will check and let you know, thanks! (and I will pray for you)
timdunbar
Aug 13, 2011 10:08 AM
rhino_e28
Jul 7, 2010 07:38 PM
98discoIN
Apr 7, 2009 10:07 AM
FALLFORWARD
Feb 18, 2009 08:52 AM
sdsilvere38
Sep 1, 2008 12:08 PM
