Sponsored by: DashLynx
hard starting 1996 disco
Old 09-20-2005, 01:20 AM
tover's Avatar
Default hard starting 1996 disco
have a problem starting my 96 disco. was told it could be the map air sensor. replace with used one still having same problem. can i get some help pleaseeeeeeeeee!
Old 09-20-2005, 02:02 AM
modyfyit's Avatar
Default RE: hard starting 1996 disco
does it just crank and crank or start and stumble whats up bro?
Old 09-20-2005, 11:57 PM
Bait's Avatar
modyfyit it takes about 4 turns of the key to start this truck. after started it run as it should. talk to land rover mech. about this and was told that if i replaced my maf air flow sensor this would take care of problem ($600 a pop) do you think this is the problem. any ideas are welcome.
[quote]problem solved. needed fuel pump (replaced). thanks all,
tover [/quote
bigr1122
07-10-2013 06:41 PM
dc10freighter
04-15-2013 12:41 PM
Paul_GPvR
09-27-2011 01:02 PM
timothyfuqua
05-30-2009 08:35 PM
martini7
09-22-2006 08:18 PM
Quick Reply: hard starting 1996 disco
