Sponsored by: CARiD
Heated rear Window
Old Apr 6, 2007 | 03:03 AM
Desiderata's Avatar
8th Gear
Default Heated rear Window
I should tell you before i start this that i am an electrical engineer. I have just bought a 15 year old defender 90 200tdi, the heated rear window doesn't work and the haynes manual i used is not very clear as far as the electrical schematic goes. before i dissasemble (no.5) my dash board to gain access to the relay in question has anybody got any clever suggestions ? i have tested at the switch and i do not have 12v on either leg. i have checked the fuses and all are ok. PLEASE HELP !! or else i will just have to free up a day which aint easy . !!
Old Apr 6, 2007 | 10:31 AM
fire1427's Avatar
Default RE: Heated rear Window
I'll assume you checked for voltage on the rear window??? and that the other lead is indeed grounded ???
Old Apr 6, 2007 | 03:41 PM
Adz's Avatar
Adz
Mine's doing the same ('93 L plate 200 Tdi deepender) - haven't really looked into why yet but did notice a 'spare' (as in not currently plugged into anything) connector block hanging under the rear crossmember while I was jet washing the underside earlier.
Have a quick look under the back of yours, if you've got the same thing there we might have found a 'quick fix'.
Is the relay for it not under the fuse box cover in the cab then?
Old May 4, 2007 | 09:45 PM
Desiderata's Avatar
8th Gear
i wished it were, according to the haynes bible it is behind the dash and i have removed it enough to see it there, however to actually lay my hands on it i will have to disconnect the world and its mother. not a problem now because its spring/summer but by autumni may well have a bigger issue. ( no im not homeless ) . I am toying with the idea of just rewiring it from scratch. it may be an easier option than trying to get to the bottom of my problem.
Thankfully i love a challenge. ;-)
twoxred
Oct 4, 2021 07:07 AM
grandkodiak
Apr 2, 2011 08:46 PM
G4AKumar
Feb 26, 2010 04:33 PM
ljdiscovery
May 22, 2008 10:30 AM
dcox
Dec 29, 2007 12:24 PM
