Sponsored by: CARiD
Help with dying engine
Old Mar 24, 2012 | 12:21 PM
beanpitt's Avatar
7th Gear
Default Help with dying engine
Hi Guys
Sort of new to the forum been here since January and used past treads to resurrect a 98 p38 with good success. There is one issue I can't figure out. The truck is very hard to start you must crank it quit a bit and you have to give it gas to start. Once it starts it runs great and it always starts. Also this just started it will completely die, and once you come to a stop it restarts and runs fine(sometimes however it will shut down for a split second and then run fine).Getting code p1193.o2 sensor. What I have already done is used mass air sensor,new fuel pump and fuel pressure regulator,new crank sensor and new plugs. Thinking of changing the stepper motor?
Also one strange thing happened yesterday,I noticed the tube from the left valve cover to the plenum was crumbling so I removed it and ran to the parts house for a new one. When I came out I noticed a puddle of oil under the rear of the engine and on the firewall. I replaced the vacuum hose and the leak stopped.
Any help would b great Thanks Chet
Old Mar 24, 2012 | 12:53 PM
The valve cover vents (PCV system) have an oil separator on one side, pull out and clean it or blast some carb cleaner in it. If plugged, can make slight pressure in places designed to be vented, and oil will come out of seals. Sounds like your IACV needs good cleaning with carb cleaner as well, do not adjust the tip. The IACV is a computer controlled air leak.
Old Mar 24, 2012 | 06:43 PM
Any vacuum leaks can cause rough engine run and hard start problems.
Old Mar 25, 2012 | 09:41 AM
beanpitt's Avatar
7th Gear
Thanks,I will check it out today and see what happens
Old Mar 25, 2012 | 05:28 PM
beanpitt's Avatar
7th Gear
engine starts better however the dying problem is still there,anything else I can look for?
Old Mar 25, 2012 | 06:45 PM
Sounds like a stepper motor issue.
Unplug it and see if there is any change in the way the engine acts.
Old Mar 26, 2012 | 11:57 AM
Jackison's Avatar
6th Gear
first check your engine if any problems solve it.
Old Mar 26, 2012 | 04:46 PM
beanpitt's Avatar
7th Gear
Tried unplugging the stepper motor and the truck started and idled high and ran rich,plugged it back in and engine ran normal. So I went for a drive and while going up a hill,engine cold, I let of the gas and she stalled. Started right up and took It on the highway for approximately 15 minute and returned to the hill and I could not get the truck to stall again. Just some info on the truck, it was off the road for 2 years someone broke into it and the owner couldn’t get it to crank and sold it to me,and yes the key code unlock sequence DOES work,but I haven’t even run half tank of good gas through it yet.
Thanks for all the help I will keep trying.
Old Mar 26, 2012 | 08:14 PM
If it is running better now it can be the ECU trying to re-learn the IACV.
tch
Oct 21, 2009 07:30 PM
sarahgibbons5
Jun 14, 2009 11:36 AM
sarahgibbons5
Jun 6, 2009 01:03 PM
hilltoppersx
Jun 2, 2009 08:37 AM
kkrover
Mar 28, 2006 11:30 PM
