Sponsored by: CARiD
Help! Fault Codes P1514, 1551, 1884
Old Jan 11, 2013 | 05:57 PM
Kobloking's Avatar
Default Help! Fault Codes P1514, 1551, 1884
I recently changed my spark plugs (to Bosch platinum plus 4s), my wires, (to Magnacore 8mm), oil filter (K&N), oil, and all four oxygen sensors. Now my engine revs irregularly and the scanner is spitting out the following three codes: P1551, 1514, and 1884. Does any body have any idea why I'm getting these codes? Is there something I can do to correct th problem or do I need to go to the stealership? Ideas please and thanks in advance.
Old Jan 13, 2013 | 02:08 PM
MichiganRover's Avatar
I just had a scan on my 01 LR Discovery. Not sure what you are driving. 1514 and 1551 are linked and are reportedly "replace idle air control (IAC) valve. I went to O'Reily auot and had a free scan, that is what their computer suggested to help with those codes. Not sure about the other. And, I am a newb so extra guidance is recommended
Old Jan 14, 2013 | 05:16 AM
Kobloking's Avatar
I drive a 99 D-II. I am new on this site as well. Someone told me the the same thing that I need an OSCAR valve and I've already ordered one. Thanks.
Old Jan 14, 2013 | 08:12 AM
Here is a page from the Bosch manual for Rover ECUs, which has both the codes. They are related to wiring/connector issues with the IACV (idle air control valve), or the unit shorting out internally. Once resolved, the 1884 code should go away, the tranny computer and engine comper are always talking on the data buss about how much power has been requested by her majesty and what gear to select to move swiftly along the cobblestones. What is an OSCAR valve?
File Type: pdf
Old Jan 15, 2013 | 04:49 AM
Kobloking's Avatar
What's an OSCAR valve? I never heard of that. I checked out the codes Savannah Buzz sent. I already ordered the IACV. It should be getting here today or tomorrow.
Old Jan 15, 2013 | 08:45 AM
re: I need an OSCAR valve and I've already ordered one
re: What's an OSCAR valve? I never heard of that
I'm still looking for the flux capacitor..... here's the shop manual page on the IACV, you may need new clamps as well.
File Type: pdf
Old Jan 16, 2013 | 06:11 AM
Kobloking's Avatar
Oscar was a typo folks? Meant IACV. Unfortunately, I was replying using an iPad and obviously IACV is a word it never came across. So IACV was substituted for OSCAR. Lesson folks, always spell check. Sorry for that loopy posting. Savannah Buzz thanks for the heads up about also needing clamps.
Old Jan 20, 2013 | 02:41 AM
Kobloking's Avatar
I put in a new IACV valve. I'm still getting the same codes (P1551, P1514, and P1884). I erased them post installing the new IACV valve but they came back when I re-scanned. Even worse, I'm now also having a P1590 (oxygen sensor) code, even though I changed all four oxygen sensors about seven months ago with new ones --do they go out so quickly? I am now also having a P0102 code. Help!!
On the bright side, the car seems to be idling better than before I changed the IACV valve.
Old Jan 20, 2013 | 03:20 AM
Kobloking's Avatar
By the way, I also want to mention that I changed the MAF as well. The scan is also showing the following on monitoring or MIL (I don't quite remember which one at the moment): "Evap" and "catalyst". The MAF I changed about two weeks ago. The IACV valve I only changed yesterday. Could it be that the codes are till coming on because I only erased them today and drove for about five miles; that I need to drive a lot more miles for the vehicle to reset itself?
Old Jan 20, 2013 | 07:39 AM
P1514 IACV opening coil malfunction Open circuit - opening winding
P1551 IACV closing coil malfunction Open circuit - closing winding
IMHO you need to check the connectors for the unit, shale the harness, etc., and reset codes again. There are two windings, one closes the valve, one opens it. They can't be open all the time or you truck would idle poorly.
P0102 Mass or volume air flow low input MAF signal < minimum threshold, which is speed dependent
The air flow is below that which the ECU has stored as a realistic value for that engine speed. Look for leaks, cracks, and splits in hoses and lines between the MAF sensor and the engine which admit "un-metered" air (also called vacuum leaks).
P1590 ABS rough road signal circuit malfunction Hardware is OK, but SLABS ECU is sending an error signal
1590 has nothing to do with O2 sensors
Look up codes in the RAVE or other Rover publication, generic lists from code readers and do-all web sites may not be accurate.
06Range
May 8, 2013 09:01 PM
Kobloking
Jan 12, 2013 12:27 PM
DiscoBenjamin
Jul 7, 2011 01:19 PM
tailchaser0527
Jan 18, 2010 07:53 AM
