Help - LR2 Problems
Help - LR2 Problems
I have a 2008 LR2 (automatic) that is parked in the garage for 35 days at time because I work away from home. This time around I've come home and gone to use it; it started no problem, I put into reverse and it would not move, put it in drive and it would not move. With both of the aforementioned actions I could feel the car pulling a little and it would rev if I pressed the gas peddle, but still would not move. I did not try to punch the gas peddle however as I did not want to go flying into the townhouse behind me or into my own and was worried that I could cause more damage to the vehichle. I should also mention the E-break was not on.
Are there any mechanically inclined people out there with some advice or knowledge on what the problem could be befor I call a tow truck? as I mentioned before, my time at home is always limited and I will be away twice as long this time, perhaps I should wait till I come back home next time as i'm sure it being parked for such long periods has something to do with it.
