Sponsored by: CARiD
Help my landy s driving me crazy
Old Jul 13, 2012 | 08:27 AM
landamqabba's Avatar
Default Help my landy s driving me crazy
I wasn t using it and left it parked for nearly a month, then i needed it for some errands and it worked fine for the first run (maybe 5 minutes drive) then i parked it and after a few minutes i went out again and when i reached 4th gear it started vibrating a lot till i got back home it strated vibrating from second on.
When i say vibrationg it feels like you have a puncture and there is no punctures. I didn t use the 4x4 so it s not stuck.
the land rover is a 1977 series 2 with a 2.5l rover engine and 4 speed box
any suggestions where i shall have a look first?
Old Jul 13, 2012 | 11:01 AM
Bkreutz's Avatar
Crawl under and check your rear driveshaft u-joints. That's where I would start.
Old Jul 13, 2012 | 02:52 PM
Scharfire's Avatar
Yup check those ujoints. If it has been a while since replacing them I would just put new ones in. They are like 7bucks each. Also check the yokes for movement. If it's not there pull the third member and check the spider gears for movement.
Old Jul 13, 2012 | 05:57 PM
Things rust when not being used, including u-joints.
Old Jul 15, 2012 | 08:05 AM
well i tried it again this morning and the front prop shaft cane undone from the differential side.
what i found strange was that the rear part of the shaft kept on turning untill i changed to low and back to high a few times.
Old Jul 15, 2012 | 03:02 PM
Your u-joint broke, that was the vibration.
The prop shaft kept turning because it was under power and with no resistance it turns super easy.
Old Jul 16, 2012 | 08:14 AM
now it stopped turning and the u joints didn t break the nuts just came undone from the diff side. the u joints don t have play as i check them regularly and grease them every month or so
jacekk
Oct 7, 2013 12:25 PM
ewatk
Nov 1, 2011 03:21 PM
Boots63
May 5, 2011 04:29 AM
sloppyjoe
Dec 2, 2008 02:22 PM
Bill E
Mar 10, 2008 01:03 PM
