Sponsored by: CARiD
HELP!On vacation and rear windows won't roll up!
Old Jul 25, 2005 | 01:59 AM
slamwhit's Avatar
Default HELP!On vacation and rear windows won't roll up!
Our 95 Disco's rear windows won't roll up! Any idea of what we can do?
TIA!
Old Jul 27, 2005 | 10:35 PM
duboff's Avatar
Default RE: HELP!On vacation and rear windows won't roll up!
the on vacation solution is if you can get the window in the up position and duct tape it in place. If not the old plastic bag trick will get you thru. More than likely the problem is with the regulator. The problem is common. If you are a do it yourself type. the fix is a pain, but not difficult. parts about 100-150buck. 2-3 hours and a cold one. Get your parts from other than the dealer. they will most likely be the most expensive. I have had two go out. I cussed both times. The big deal is keeping the window from being damaged. hope it helps. gotta love a rover. duboff
Old Jul 13, 2006 | 11:01 PM
bookerbr's Avatar
Any instructions on how to replace the front left window regulator, mine just went out. I have a 2000 disco. Thanks
Old Jul 14, 2006 | 08:40 AM
The other thing that will cause your rear windows to not work is the small ecu that helps operate the windows, it is common to have it fail. I would look at that as your problem since it is not very likely both rear window regulators have failed.
Mike
Old Apr 19, 2017 | 01:29 PM
M1k3's Avatar
4wd High
Check the sticky section - there is a post on where to solder some dry joints in the Window ECU that lose connectivity over time. I just did it a few weeks ago.
Repairing the Window Lift ECU - How To
Old Apr 20, 2017 | 12:26 PM
abran's Avatar
its been since 2006, the disco is probably flooded by now...
txjag1023
Mar 9, 2012 12:27 AM
SC Rovergirl
May 15, 2010 07:06 AM
01DiscoII
Apr 9, 2008 01:02 PM
95discotn
Oct 13, 2004 09:28 PM
95discotn
