Sponsored by: CARiD
Hitch Key/Lock Assembly
Old Jan 16, 2025 | 02:11 PM
Abram's Avatar
Default Hitch Key/Lock Assembly
Hi everyone, I couldn't find a clear answer in my searches here so I hope this hasn't already been covered. The LR4 I recently bought had a hitch receiver installed but the key portion was missing and unfortunately the lock cylinder was bent & damaged. Through some careful disassembly, I was able to remove the damaged cylinder and also remove the hitch itself but that part is definitely unusable. The hitch seems fine after some cleaning but I will need an entire lock assembly (plus keys) and I can't seem to find any info on getting the whole thing without buying an entirely new hitch. I know one can purchase the lock cover and keys (the green portion) but I haven't been able to find the whole lock assembly.
I'd like to still be able to use the hitch for my bike rack when desired but I don't want to just leave it on all the time. Am I out of luck or is my Google-fu just weak?
Old Oct 10, 2025 | 10:05 PM
cavenger123's Avatar
curious if you had any luck?
Old Oct 10, 2025 | 11:33 PM
Abram's Avatar
I did yeah! I was able to clean everything out and do a rebuild. I salvaged all the parts except for the lock cylinder and I got a replacement key and key cover. I ordered a replacement cylinder from https://landrader.com/the-shop. Wasn't the cheapest thing but it resolved the exact problem I was having.
Works just great now! Even just used it again last weekend with my bike rack.
TopGunRover
May 21, 2015 06:40 AM
rmarc71
Feb 22, 2012 04:23 PM
bribake
Feb 17, 2012 10:51 AM
Kevin Kelly
Dec 22, 2011 04:35 PM
