Sponsored by: CARiD
Ignition key stuck in barrel!!!!
Old Feb 29, 2008 | 08:27 AM
denis06's Avatar
Default Ignition key stuck in barrel!!!!
My ignition keywon't turn in the barrel and there are alot of metal filing around its mouth. Is this a common problem with the Discovery TD5 1999? Can I do anything inexpensive to resolve it?
Old Feb 29, 2008 | 08:57 AM
Default RE: Ignition key stuck in barrel!!!!
It's only common if you have alot of keys/weight hanging on your key chain. If you are able to get the key out, try and save your tumblers by blowing out all the metal, lite lube and have a new key made using your original key code number.
Old Feb 29, 2008 | 09:37 AM
WolfPack's Avatar
Are all LR keys as expensive as my '01 Ranges? Dealer quoted me $185, plus shipping, plus a 2 week turn around. Apparently the '01s are hand cut in England, as opposed to newer Ranges are laser cut and can thus be replicated by a machine domestically? Are Discos the same way?
Old Feb 29, 2008 | 09:53 AM
No,
With a key code number and a blank from the dealer, you can go have a new key cut easily.
Old Feb 29, 2008 | 09:58 AM
WolfPack's Avatar
Ahh...alrighty..Now I gotta woo the dealer into giving me a blank for less than $185
ImQuattro
May 1, 2014 08:36 PM
will rocket
Off Topic
Sep 12, 2013 06:23 AM
harro123
Mar 27, 2011 06:15 PM
batiscan
Dec 7, 2010 12:00 PM
Tayo
Sep 10, 2005 01:13 AM
