Sponsored by: CARiD
Im Stuck in Park! Help!!
Old Aug 23, 2009 | 07:25 PM
funkymunk's Avatar
Default Im Stuck in Park! Help!!
Hi all:
You all always do a great job of directing me, so I need your help again. This happened on and off for about a year--happening maybe 5 times total. The gear basically gets stuck in park and I can't get it out. It takes a lot to finally get it to unlock. It seems to be connected to a clicking noise in the shifter when I press the brakes. If it clicks when I press the brakes, its fine--otherwise I'm stuck. I seen on some other post without followups that it may be a break switch or shift solenoid, Any ideas? Is this something I can do myself? If so, how do I do it? I'm willing to try anything before dragging it into a shop. I have a 2000 Disco II. Thanks very much!!
Old Aug 23, 2009 | 07:37 PM
Spend a little time doing a search and you'll find it on this and other Rover forums, real common.
Old Aug 23, 2009 | 08:17 PM
funkymunk's Avatar
Uh, yea. I was looking for info on the solenoid issue--not the brake switch. Kinda crummy to be told that since no one else here was told to research it more here with all the previous posts.
Roywilliams14
May 17, 2014 01:27 PM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
RobK
May 24, 2011 08:41 PM
nohopeboy
Sep 13, 2009 10:58 PM
