Sponsored by: CARiD
indicator light on in instrument panel
Old Apr 9, 2012 | 08:10 PM
Danny Lee 97 Disco's Avatar
Yeah, it should be a dark thick oil not red at all. That is probably why he sold it to you so cheap.
You can use either the same lube in your front and rear diff as the center diff.
You should go ahead and service all three. Those are the main parts of your 4 wheel drive. They are almost bulletproof if you keep the fluids fresh and filled properly. Very expensive if you let them go.
Old Apr 9, 2012 | 08:55 PM
elpapisf's Avatar
Originally Posted by Spike555
If the fluid that came out of your transfer case was redish it was the wrong fluid, someone put transmission fluid in it, it takes gear oil.
You need a hand pump to put it back in, you can buy one for about $10 at any autoparts store.
yeah i dont know if it was the wrong fluid but it was like a redish brown color not thick at all i just added 70w140 synthetic and it was totally different from what it came out.
Old Apr 9, 2012 | 09:02 PM
elpapisf's Avatar
i just did all three, and the one in the front was kind of bluish color, nice viscosity and didnt smell bad, but the rear one was milky brown and it smelled like a strong burned fluid, i tried to flush it till the new one came out but i dont know if that was the right way to do it, so ill guess ill drive it and change it again
Old Apr 9, 2012 | 09:52 PM
The milky is water. The source is condensation, or water thru the vent tube that leaves the banjo bolt of the rear axle, and goes up toward the transfer case. The vent tube can be cleaned out, along with the banjo bolt, which can clog and not vent.
Rover505
Mar 14, 2024 11:38 AM
treihammond12
Jul 27, 2015 06:45 AM
jonnymcd
Mar 24, 2007 01:07 AM
litterlout
Aug 27, 2006 11:16 AM
James Vee
Feb 1, 2006 10:34 AM
