Sponsored by: CARiD
Indicator light meaning
Old 03-25-2012 | 09:35 PM
gcooley8's Avatar
Default Indicator light meaning
There is an indicator light in the upper left hand side of my Disco II instrument panel. It looks like the front and rear axles with the tires on them with a line connecting them with an X with a circle around it. The owners manual describes pretty much every other indicator light except this one... Go figure.. I have the 3 amigo thing going on, but this is on as well. Just bought this 2001 Disco II, with the engined replaced with one that has 78K miles. runs great... Can't figure out what this indicator light means. Can one of you more experienced guys help out a newbie?
Thanks
Greg
Old 03-25-2012 | 09:46 PM
That would be transfer case in CDL? But depending on year the dealer may have done this with a wrench if you don't have the CDL lever. Unlock CDL if you have it, should only drive on snow or dirt with this, not pavement, makes extra stress on driveline components. See attached page from owners manual, the whole thing and tech manuals are called the RAVE and available for free download.
Now if someone removed one of your drive shafts, they would have to do this to get truck to move.....
File Type: pdf
Old 03-26-2012 | 09:25 AM
An easy test for your to perform would be to go to a large parking lot and very slowly, turn as tight a circle as you can, if the steering wheel feels lurchy the your CDL has been locked up and should be unlocked, if not it is electrical and should be investigated/repaired.
Old 03-26-2012 | 12:52 PM
Jackison's Avatar
6th Gear
this is a transfer case in CDL and check your CDL has been locked up and should be unlocked, if not it is electrical and should be investigated/repaired.
Old 03-26-2012 | 06:30 PM
gcooley8's Avatar
Thanks for the info guys... Glad to be a new member of the family.... I'll Be checking in quite a bit I'm sure.
Thanks Again,
Greg
Old 03-26-2012 | 07:06 PM
Chris-bob's Avatar
Flux Capacitor is low on flux. Won't be able to travel back in time without it.
Oh, and welcome to the forums!
grunte
05-13-2015 12:16 PM
david1289
08-23-2009 12:24 AM
ne1949mozda
07-06-2009 09:23 PM
wick_60010
01-12-2009 03:02 PM
hanivw
04-23-2008 02:59 AM
