Anti Lock light intermittent
Old Sep 10, 2013 | 06:15 PM
Michael Haas's Avatar
7th Gear
Default Anti Lock light intermittent
I understand there are 4 anti lock sensors, one at each wheel. My "anti lock" light goes on intermittently. When it is ON, the brakes are consistently fine. When it is OFF, it will occasionally fail to stop well, bounce/vibration at the pedal with a definitely noise (funny, sounds like a old garage door spring).
Mechanic said one of the sensors is bad and has to basically replace all. No can do $$. Can the sensors be disconnected one at a time to diagnose which one is bad? Any ideas??
Appreciate any help!
Old Sep 10, 2013 | 06:26 PM
CUpgt's Avatar
Come to the dark side. Pull the fuse and the dash bulb and forget about it.
Old Sep 10, 2013 | 06:48 PM
7th Gear
Default Anti-Lock light
My Discovery is a 96 SE.
Old Sep 10, 2013 | 06:50 PM
7th Gear
Haha! Light doesn't bother me, it's the intermittent issues at the pedal. So with he fuse pulled, pedal should operate normally?
Old Sep 10, 2013 | 07:18 PM
CUpgt's Avatar
If you pull the underhood fuse for ABS it just disables it and your brakes operate like a normal non-abs system.
Old Sep 11, 2013 | 01:54 PM
7th Gear
done, very cool: thank you
thearmlesswonder
Dec 10, 2014 10:27 AM
fitz1j
Dec 16, 2010 11:38 AM
redhotbuzz
Aug 25, 2008 08:32 PM
briauna2003
Aug 15, 2008 08:37 AM
sfxgamer
Jun 19, 2007 02:29 PM
