Sponsored by: CARiD
Always wants to be in 4WD.....
Old Dec 24, 2012 | 08:57 AM
MrRover's Avatar
3rd Gear
Default Always wants to be in 4WD.....
Hi everyone,
I poked around the siet looking for similari mentions and remedies perhaps of my ailment, or the vehicles ailment. In question is a 97 Land Rover Discovery SE and seeminly no matter what I try it always goes into 4WD. One time even when I went to get on the highway I found I was in 4- Lo. As it is I'm stuck driving around in 4-Hi. I wonder if this might be something like an actuator/ solenoid thing of sorts. I just don't know where to look. Any pointers or direction to a walk thru fix would be most greatly aappreciated..............
THanks
Old Dec 24, 2012 | 09:23 AM
That is not going to happen, there is nothing electrical that can cause you to go from High to 4 Low without your shifting it.
Old Dec 24, 2012 | 10:10 AM
And usually the problem is the shifter is stuck from lack of frequent use, not so sloppy it flops around by itself.
Old Dec 24, 2012 | 06:26 PM
MrRover's Avatar
3rd Gear
Shifter misaligned, hmm- sounds like something. how do I verify this..............
Old Dec 25, 2012 | 01:43 PM
Michael M. Koch's Avatar
What he said.
You have a CDL (Center Differential Lock) shifter in front of your normal gear shift lever. For normal driving it should be all the way back, towards you, and to the right. This is "all-wheel-drive," meaning whichever of the four wheels has the best traction at any given moment will receive 100% of the power the drivetrain is putting out. (The truck isn't really a true 4-wheel-drive. The CDL locks the differentials together so one front and one back wheel will spin.)
Old Dec 25, 2012 | 10:08 PM
It is a full time 4x4, it is always in 4x4 mode, always.
Old Dec 26, 2012 | 01:34 PM
MrRover's Avatar
3rd Gear
K- thanks. I'm writing kinda from a distance, I've pareked the thing- I'll look at it when I get back to it. Thanks again..................
xstreetz
Sep 21, 2007 12:15 PM
elguappo999
Nov 16, 2006 04:48 PM
ebone
May 21, 2006 03:02 PM
wkujesus2
Apr 19, 2006 12:15 AM
