Sponsored by: CARiD
Key fob not working after battery replacement, re sync problem
Old Jun 19, 2017 | 02:12 PM
jrf07d's Avatar
3rd Gear
Default Key fob not working after battery replacement, re sync problem
I recently replaced my vehicles battery and now the key fob will not lock or unlock my vehicle. I have followed the re sync steps seen online however they have not worked for me. I have replaced the battery in the key fob before and did not have a problem with needing to re sync. any help would be greatly appreciated for instructions on how to re sync maybe I am doing something in the wrong order or need to take my rover some place and have the key re synced with a special tool maybe?
thanks for the help
the re sync I have tried:
1. enter vehicle and make suer all doors are shut and locked
2. insert key into ignition
3. turn key to position 1, turn key to position 0 and remove within 5 seconds
4. within 25 seconds preform the following steps
5. press and hold the unlock button
6. press lock button 3 times
7. press both unlock and lock together
this did not work of me but maybe I am not doing it correctly, any help would be appreciated. thanks
Old Jan 14, 2022 | 03:19 PM
PJS's Avatar
PJS
thanks for the help
I know this is an old post but I'm having the same issue with a 2017 Evoque that only has a key fob, no actual key. Did you get this resolved on your own?
Hayseed_D5
Mar 29, 2026 05:04 PM
dtm325
Nov 1, 2013 11:50 AM
Popsickle
Mar 10, 2013 08:39 PM
Jo1175
Dec 9, 2011 06:56 PM
Camdisco24
Jan 24, 2011 07:35 PM
