Sponsored by: CARiD
Key won't turn...ignition switch replacement?
Old Dec 14, 2009 | 01:40 PM
Disco Canuck's Avatar
Default Key won't turn...ignition switch replacement?
I thought I may have a failed brake switch, but after talking to a few people, it may appear bigger and would like to see if anyone have some thoughts or advice.
2000 Disco II around 120k miles
Parked the disco the other night, and tried to start it in the morning and the key will not budge, like the steering column is locked.
Tried to unlock, tried looking at all the fuses and anything else I can imagine and then went to the local dealer today, who told me it was going to be $1000 and a month wait to replace the ignigtion switch.
Anyone know a repair shop in the NJ/NYC area?
Thanks
Old Dec 14, 2009 | 02:45 PM
Baylink's Avatar
This is pretty obvious, but I'll mention it anyway:
It is possible, after you turn the key to 0, for the steering gear to *lean* on the key interlock so hard that you can't turn the key.
Have you put the key in, and rocked the wheel back and forth a little bit to see if it releases the key to turn?
There are lots of interlocks on a Landy, but I'm *not* aware of one that keeps the key from turning.
Old Dec 14, 2009 | 09:03 PM
mjbrox's Avatar
i had the same problem
Try http://www.triflowlubricants.com/
not wd-40
RobsRover
Apr 13, 2019 03:33 AM
toad2
Jan 17, 2014 09:19 PM
tgvas
Dec 28, 2011 09:13 PM
Lwulf
Jan 31, 2011 02:55 PM
babylucy
Dec 4, 2008 10:37 PM
