Sponsored by: CARiD
Knock censor location
Old Sep 14, 2015 | 08:03 PM
Rovergirl2001's Avatar
4th Gear
Default Knock censor location
Hello, I am new to this forum. I have a 2001 Land Rover Disco II. This is my second disco II. My check engine light was flashing so I took in into advance to have the codes read.
P0314 (02 sensor- multiple codes for this -Bank 1 sensor 1 and Bank 2 sensor 1)
PO327 ( knock sensor bank 1)
And cylinder misfire codes for cylinders 1,4,5,6
I was told to get the P0327 changed first. It is a Knock sensor. Does anyone know where the knock sensor is? I can only find one image online, but I can not locate it from the photo. Any feedback is greatly appreciated.
Old Sep 15, 2015 | 11:27 AM
abran's Avatar
Knock sensors are at the base of the block approx 2" up from oil pan seam in the middle of the block. If you could get an actual Land Rover code reader you might get more info. If you are near so cal I can read them for you.
coors
Jan 11, 2013 09:28 PM
gtuplin
Jul 15, 2012 12:18 PM
salve7
Jan 7, 2010 02:34 PM
targotsi
Feb 18, 2009 05:58 PM
stick
Jan 27, 2008 01:29 PM
