Sponsored by: CARiD
Knocking sound around top front of engine
Old Jun 15, 2013 | 04:05 PM
SeizeTheDay's Avatar
3rd Gear
Default Knocking sound around top front of engine
I noticed a tapping sound 2 days ago. It has gotten progressively worse. It sounds like a metallic tapping and it seems like its coming from around the pulleys or the air conditioning compressor. The AC is working fine at this point. Any ideas what this might be???
Old Jun 15, 2013 | 04:17 PM
So, what have you checked so far? I hope you are not continuing to drive it or you will have a major issue.
Old Jun 15, 2013 | 04:29 PM
3rd Gear
I don't know where to start. The pulleys seem to be tight. Would the AC compressor make that sound? This is an '01 disco II by the way.
Old Jun 15, 2013 | 05:36 PM
If you are sure it is on the front of the engine, it will either be a failing oil pump, if not, you need to remove the belt and spin/check each belt driven pulley for a noise or roughness, including the water pump.
Old Jun 15, 2013 | 07:07 PM
3rd Gear
Ok. Turning the AC on makes it quiet.
Old Jun 15, 2013 | 08:33 PM
You can take a yard stick, put flat side against your ear, and touch other end to various spots. Sound travels very well thru a solid, and you will hear it in more detail. Be sure to listen to valve covers in several spots. Alternator. pumps, AC compressor, etc.
mowensmd
Aug 21, 2024 11:07 AM
Timothy Wright
Oct 2, 2012 04:51 PM
0304Disco
Sep 1, 2011 03:28 PM
larryrover
Mar 1, 2009 03:48 PM
MichiganJim
Nov 30, 2007 07:42 PM
