Sponsored by: CARiD
Landrover series help
Old Sep 6, 2008 | 12:29 PM
vincey's Avatar
Default Landrover series help
I aquired a series landrover 6 months ago and as of yet have been unable to get the brakes to be of any use what so ever
there is no air in the system, its been bled and bled and bled again ,, its been pressure bled , vaccuum bled jacked up at the rear and bled jacked up at the front and bled, infact its been bledevery which way but loose.
if I clamp off the rear brake hose which supplies the rear ,I get a fantastic pedal, without it I have to pump the pedal a few times to get a pedal, ( I know your going to say its got air in the rear , but it hasn't )
I have investigated this a bit more and it looks like the rear wheel cylinders are the same as the front , now I thought that the rear ones were of a smaller bore , if so could ths be the problem due to more fluid bein needed to push the pistons out,
does anyone know if the rears are of a smaller bore
or am I clutching at straws here
Old Sep 6, 2008 | 01:08 PM
Default RE: Landrover series help
Year, model and mileage?
gbene59
Aug 31, 2011 09:43 AM
dengwe
May 7, 2011 05:32 PM
kallu
Dec 22, 2010 01:18 AM
renermacy2
Aug 9, 2009 10:45 AM
G1975
Jul 25, 2007 01:19 PM
