LandRover Series II
Old Aug 29, 2011 | 03:42 PM
gbene59's Avatar
Angry LandRover Series II
I just replaced the master cylinder thinking that was my problem with my brake's I have none bled all 4 side's still no brake's it say's to use dot 4 brake
fluid I put 3 you think that would make a difference?
Old Aug 29, 2011 | 03:44 PM
You better flush out that DOT3 with 2 quarts of DOT 4 and did you bleed the master cylinder before you installed it?
Old Aug 29, 2011 | 04:03 PM
buick215's Avatar
Why did you put in DOT 3 if you knew that it ask for DOT 4. I would change it if I were you. Land Rovers are very picky when it comes to fluid types.
Old Aug 29, 2011 | 08:42 PM
disc oh no's Avatar
Even with the wrong fluid shouldn't you have SOME brakes? Ofcourse, if it wasn't bench bled before installation... it's not going to work anyway.
Old Aug 30, 2011 | 09:41 AM
gbene59's Avatar
How do you bleed a new master cylinder first time i've heard that one anyway I do have
fluid coming out all for bleeder's on the the wheel's and still no brake's at all how do you
explain that?
Old Aug 30, 2011 | 10:10 AM
sloan74's Avatar
when you pump the brake petal 8-10 times all the way to the floor do you feel any pressure building up?
Old Aug 31, 2011 | 09:43 AM
So quit screwing around, bleed the master cylinder then do a full 2 quart DOT 4 bleed and see how they feel.
dengwe
May 7, 2011 05:32 PM
kallu
Dec 22, 2010 01:18 AM
renermacy2
Aug 9, 2009 10:45 AM
vincey
Sep 6, 2008 01:08 PM
G1975
Jul 25, 2007 01:19 PM
