Sponsored by: CARiD
Location of Crank Position Sensor?
Old Feb 21, 2008 | 04:42 PM
lacruiser's Avatar
5th Gear
Default Location of Crank Position Sensor?
Hi folks. I am hoping that someone out there might know the answer to a few questions:
I have a California-spec 2001 Land Rover, 4.6 SE.
The engine quit running, cranks normally, and the diagnostics point to a bad Crank Angle Sensor.
So I bought a new one (part number ERR 7354).
Where on the engine is this located? I've been told it's on the bellhousing, but I can't see it anywhere, and the covered portions look like they'd be a real pain to access.
On the other hand, I do see a sensor of some sort at the front of the engine, right above the crankshaft pulley. Is that the Crank Position Sensor?
Is there any trick to installing this sensor? Like does the engine crankshaft have to be in any particular position before removing the old one? Or is it a direct bolt-in replacement (keeping in mind issues such as spacers, clearance, etc).
And finally, is there any reprogramming procedure necessary after it's replacement?
thanks for any assistance/suggestions.
Dana
Old Feb 22, 2008 | 04:07 AM
Savannah's Avatar
Default RE: Location of Crank Position Sensor?
Hi Dana.
The sensor you see just above the crankshaft pulley is the Camshaft sensor and not the Crankshaft sensor.The sensor you are looking for is on the engine block where the engine and bellhousing meets.If you stand in front of the engine,the starter motor will be on the left.In the same position,but on the right ,will be the Crankshaft sensor.It sometimes has a cover with 2 bolts.There is no reprogramming required.
Regards
Marius
Old Feb 22, 2008 | 03:56 PM
greg409's Avatar
I looked on my rave cd & although your 4.6 crank sensor is a different # than my 4.0 it's in the same location, driver's side below the exhaust manifold, into the bell housing w/2 small bolts.
On your's, the two small bolts hold the heat sheild cover on w/the sensor, mine doesn't use the cover, so my '96 RR 4.0 sensor is quite visible.
On the rave cd, it's listed under engine - from MY (model year) '99
sub directory -- fuel system - repair shows drawings & details
Old Feb 22, 2008 | 05:03 PM
lacruiser's Avatar
5th Gear
Marius and Greg, thanks so much for the clear descriptions. It's raining out right now, but when it clears, I'll go take another closer look.
Dana
Old Feb 28, 2008 | 02:16 AM
superpowerdave's Avatar
Dana if you're still looking for this it is exactly where stated on the right side of the engine (if you're looking at it.) There is a black plastic cover held in place by two 10mm bolts, and once that is withdrawn there are two 8mm bolts holding the sensor in place. Disconnecting the sensor is a lot easier to do than connecting it.
Old Feb 28, 2008 | 07:24 AM
David knows what he is talking about, his crank sensor failed while driving from the East coast a couple monthes ago, he had to replace his while on the road.
4Low
Sep 17, 2014 03:28 PM
Woody Reems
Jul 14, 2009 08:30 AM
wosmo
Aug 7, 2008 11:24 PM
DiscoOn22s
Apr 19, 2008 05:12 PM
icoolyou
May 16, 2007 05:50 PM
