Sponsored by: CARiD
Location of Disco II engine serial number
Old Aug 7, 2009 | 05:41 PM
eurochop's Avatar
3rd Gear
Default Location of Disco II engine serial number
I'm trying to find the location of the serial number on the engine block for my 02 Disco II. I am told it has the format xxDxxxxx where the x's are numbers. I couldn't find anything like that on the block, all I could find was this:
http://dl.getdropbox.com/u/1036059/DSCF0677.JPG
http://dl.getdropbox.com/u/1036059/DSCF0678.JPG
http://dl.getdropbox.com/u/1036059/DSCF0679.JPG
Hoping one of you could help.
Old Aug 7, 2009 | 06:30 PM
What are you needing the number for? Just curious and can't remember the location of the number either.
Old Aug 8, 2009 | 12:24 AM
eurochop's Avatar
3rd Gear
Thanks for responding Mike.
I need some new cylinder heads, but I am told there were a few different ones in 02.
I'm told there's the 94D engine series and the 97D engine series, and then they're different before and after engine # 05503A. (using hollander interchange)
Apparently the engine was changed mid-way through 02, and the older style 99-02 disco & 96-02 range rover. Newer style fits 02-04 Disco II and some 01's.
I'm also curious just to know where it is just for future reference.
Old Aug 8, 2009 | 08:09 AM
I believe the only difference was if you have SAI on your truck, that should be the only issue for you.
Old Aug 8, 2009 | 09:34 AM
eurochop's Avatar
3rd Gear
Yes, there's SAI on my Disco II. However, Hollander is usually trusted software when it comes to compatibility, and they say there were two types of heads w/ secondary air injection:
(1) fits
LAND ROVER DISCOVERY II 01-02 w/secondary air injection, 94D eng series, thru eng #00000A
LAND ROVER DISCOVERY II 01-02 w/secondary air injection, 97D eng series, thru eng #05503A
LAND ROVER DISCOVERY II 99-00 w/secondary air injection
RANGE ROVER 96-02 w/secondary air inject sys
(2) fits
LAND ROVER DISCOVERY II 01-02 w/secondary air injection, 94D eng series, from eng #00001A
LAND ROVER DISCOVERY II 01-02 w/secondary air injection, 97D eng series, from eng #05504A
LAND ROVER DISCOVERY II 03-04 (Discovery), w/secondary air injection
I'm just hoping to find the engine serial # to figure out if I have type 1 or type 2. Unless you know for a fact that they are interchangeable.
Old Aug 8, 2009 | 12:06 PM
d2luvr's Avatar
try looking around your dipstick probably behind the manifold. Thanx to the RAVE manual on my desktop.
jbryant
Jun 2, 2013 09:43 AM
srbaker
Dec 11, 2010 02:17 AM
kae
Mar 12, 2010 09:11 AM
kae
Mar 11, 2010 09:22 AM
cjn104
Sep 21, 2004 09:31 AM
