Sponsored by: CARiD
locking
Old Apr 18, 2016 | 05:39 AM
Hawkins3231's Avatar
7th Gear
Default locking
Ive just bought a 96 discovery and it wont lock, i only have the spare key and when younturn it in the key hole, the key hole falls out, also if i push the lock on the inside and then slam the door it just reopens the car, any thoughts ?
Old Apr 18, 2016 | 08:10 PM
stillruns's Avatar
the keyhole falls out?
Old Apr 18, 2016 | 08:26 PM
7th Gear
yes when you try take the key out the metal part of the key hole comes out with the key
Old Apr 20, 2016 | 11:39 AM
partsguru's Avatar
You'll need to pull your trim panel, remove the outer door handle (easiest that way) and find the "modified e-ring" that should be holding the cylinder pawl and the cylinder into the handle (I've got a picture in my recent post @ drivers door handle fell apart), you'll probably find your goodies in the bottom of the door. Your lock/unlock problem is probably related. Check your pictures in the RAVE body manual. Russ
Old Apr 24, 2016 | 03:44 AM
7th Gear
Cheers mate found the part to hold he key hole in but still won't lock going to buy a new locking system for it
johanba
Apr 3, 2007 11:37 AM
ajh
Jan 6, 2007 07:30 PM
paul7829
May 17, 2006 08:42 AM
gazthevan
Apr 14, 2006 01:28 PM
arocena409
Oct 17, 2005 09:41 PM
