Sponsored by: CARiD
LR4 Cylindrical object left underside, what is it for?
Old May 4, 2013 | 10:57 AM
roverguy7's Avatar
I'd like to see the screen, as it shows height sensor inputs.
The only justification I can make for the rear being high, is that it hasn't tried to lower it, since it's trying to, and unable to raise the front from under access.
I do not recommend driving it if it is all the way down, you will cause unneeded wear on your suspension components. There is no 'back up' suspension.
One thing to try, but may end up getting you even worse off, is to see if you can lower the truck with the switch. If the rear comes down, the front may be able to raise a little as weight is transferred. But this may also just lower the rear all the way too.
Old May 4, 2013 | 12:25 PM
stmcknig's Avatar
Which is why when I have to take my LR in for work involving a lift and it's not a shop that deals with air suspension or the Rover on a regular basis I remind them to be careful to only use the chassis on the driver side and not screw up my compressor or reservoir.
When I got the new AMK unit which comes with new covers, I notice it now carries a molding with a warning for not a jacking point....
Old May 4, 2013 | 12:29 PM
The-J-Man's Avatar
6th Gear
The rear went down ages ago all ready. That was just directly after lowering the car from the jacking machine.
The entire car was in access mode for the last day not raising above that.
I had to get to the airport, leaving th country for a week (real bad timing) so i started driving there, slowly. Not going a above 40km/h. 10 minutes later the 4x4 screen said its in normal height. The switches said that too. I got out and checked. Indeed it was at the standard height.
Sadly I cant take a picture anymore. But it showed exactly what you would see when you lower the car to access height.
Just at the end now, it was at normal height.
Seems like there is some life left in the system. Really weird.
The car felt a little bit bouncy at first then normal.
Ill be back in 1 week (work travel ) Ill have to wait and see what the car looks like next week.
thanks for your help
Well they got it right 4 times all ready. Just now they screwed up badly.
They should put a huge sticker on that area I think.
Better idea, add a sensor that makes the horn go mental when excess pressure is applied. That would be effective haha
Old Jan 17, 2025 | 08:23 PM
James Mcgrew's Avatar
3rd Gear
Mine has rusted out what is a proper name to order this Cylinder or Pressure tank
Old Jan 18, 2025 | 08:12 AM
Racer X's Avatar
Reservoir Tank, P/N RQN500070
Atlantic British has genuine ones for sale. https://www.roverparts.com/suspensio...3z6hhXhzrc2dV0
Old Jan 18, 2025 | 06:43 PM
3rd Gear
Thanks to all I ordered last night. now on to manuals
bradical
Jan 3, 2012 10:04 PM
coors
May 11, 2011 08:14 PM
Savannah Buzz
Feb 25, 2011 10:23 PM
tornado_735
Mar 13, 2009 07:34 PM
avking
Feb 18, 2009 05:10 PM
