Sponsored by: CARiD
My Ball(joint)s are frozen (03 D2)
Old Mar 21, 2018 | 04:03 PM
stxscott's Avatar
Default My Ball(joint)s are frozen (03 D2)
I had a bugger of a time but successfully removed drive shaft and hub carrier.
Next step is to remove the ball joints from the axle. I bought a ball joint tool online but it's woefully inadequate. Seems these kits never contain all the right fittings needed.
My upper ball joint is frozen. I've sprayed it. Tapped it. And tied to use the press in an awkward fashion, but can't get the bugger to budge.
Any tips to unfreeze my ***** would be helpful.
Old Mar 21, 2018 | 06:11 PM
JUKE179r's Avatar
Use a very hot butane torch to heat up and expand the spindle hub that the ball joints are pressed in.
Old Mar 22, 2018 | 06:23 AM
stxscott's Avatar
I have a propane torch so I can give that a try - thanks.
austinlandroverbill
Feb 16, 2017 07:57 AM
austinlandroverbill
Feb 12, 2017 10:19 PM
Newbie
Nov 13, 2007 09:25 AM
jeff07ski
Nov 5, 2007 01:30 PM
pom1987
Apr 20, 2006 04:37 AM
