Sponsored by: CARiD
My first land rover
Old Mar 5, 2008 | 08:36 AM
herblatham's Avatar
Default My first land rover
I just got a 1998 Land Rover Disco LE, has 119,000 miles on it. The person that had it before me was using synthetic blend, I want to go to full synthetic. Do I still need to flush the engine with ATF before converting? Also, I had a hard time switching the diff. lock from high to low, and vice versa, Is it pretty simple to change that oil as well? Any other maintainance suggestions that I should do to the car? Any help greatly appreciatted. Had the car about a day now, and already in love.e
Old Mar 5, 2008 | 09:44 AM
Default RE: My first land rover
What does the inside of your oil fill cap look like? If it still has alot of build up, I would flush the engine.
As for the t/case and it's shifting issues, it is not your fluids, it is the linkage. Work on shifting it every day till it loosens up then shift it at least once a month to keep it moving freely.
If you are going to synthetic, go all the way to slow down the wear factor, diffs, t/case, p/s and brake fluid.
EL GALLO
May 1, 2010 12:40 PM
tornado_735
Mar 28, 2009 05:34 PM
Heybuck59
Mar 7, 2009 05:02 PM
sloppyjoe
Nov 5, 2008 05:24 PM
Skibum232
Nov 20, 2007 05:46 PM
