Sponsored by: CARiD
Need help with the 3 amigos (abs/downhill/tc)
Old Dec 12, 2009 | 06:06 PM
ManMover's Avatar
5th Gear
Default Need help with the 3 amigos (abs/downhill/tc)
I cannot figure out what to do with all of these lights on my 2000 series 2. I see there have been many with this. Is it a recall? If not what is the way to fix it without breaking the bank?
Old Dec 12, 2009 | 06:42 PM
Baylink's Avatar
Well, as usual, that depends on what (if anything) is actually wrong.
Take it to a local auto parts place that has an OBD 2 code reader, and see if they get anything, and take it to a safe place and do a panic stop to see if the ABS actually fires.
And, of course, check your brake fluid reservoir for level.
Old Dec 12, 2009 | 07:02 PM
ManMover's Avatar
5th Gear
I currently have it in a buddies shop replacing the head gasket and a few other gaskets that are leaking. I unplugged the abs for safety a few weeks ago. I will have him get the codes so I can post it. When I plug it back in what am I looking for when I do a panic stop?
Old Dec 12, 2009 | 08:49 PM
Baylink's Avatar
Like all ABS systems, if you hit it hard enough to lock a wheel, you should be able to feel the ABS pulsations through the pedal.
Old Dec 14, 2009 | 05:24 AM
Photographer2009's Avatar
Here is a link that is provided by member jycsalas super moderator
This may or may not be the actual problem or fix but it may come in handy for you. I found this while researching some things earlier.
http://www.landroverclubvi.com/abs-mod.html
Old Dec 14, 2009 | 09:19 AM
Plug the damm thing back in, not sure what you thought that might fix, other then to give you more fault codes.
dbh
Dec 9, 2009 01:38 PM
cnterline
Jan 7, 2009 08:41 PM
tkeagle
Oct 20, 2007 08:34 AM
faugsu
Dec 13, 2006 10:25 PM
discodream99
Nov 10, 2005 12:54 AM
