Sponsored by: CARiD
Need Help !!!!
Old Jun 30, 2012 | 02:26 PM
1sickdisco's Avatar
3rd Gear
Red face Need Help !!!!
I recently drove my 96 Disco through deep water (3-4ft) pulling people out of flooded streets... After about 30-45 min of driving and idling in water she died, fule pump relay shut down and no fire to plugs...engine still turns over though???? Any input on this would be a big help!!!
Old Jun 30, 2012 | 02:41 PM
May have got water on the ECU, in black box between fuel pump relay and firewall, passenger side. Open it up, clean up, seal it back.
Also fuses, see attached page. My fuel pump draws like 5 amps. When key switched on ECU lets it run a few seconds, but if engine is not running it stops. Pressure test point (32-34 PSI) on passenger side fuel rail (looks like tire valve).
Might also be CKP (crank position sensor), it will kill spark, and ECU thinks engine is not turning.
File Type: pdf
Old Jun 30, 2012 | 10:03 PM
Crank position sensor, it drowned.
Thats my best guess.
Old Jul 5, 2012 | 08:13 AM
1sickdisco's Avatar
3rd Gear
Hey guys ... Thank you so much for your response!!!! I'll check those items and let you know how it goes !!
Old Jul 5, 2012 | 01:34 PM
Let us know what you find, my money is on the wet ECU. I have had my engine pretty deep in water and never had an issue with the crank sensor, they seem to be pretty water tight.
Let us know what you find.
Old Jul 5, 2012 | 07:09 PM
antichrist's Avatar
If it died in water 4' deep there's a good chance you have water in the cylinders unless you have a significant lift. Pull the plugs out before you crank it the first time to avoid a bent rod.
ScreamingLife
Apr 25, 2013 08:32 PM
MuddMouth
Oct 18, 2010 03:01 PM
striversrowatl
May 1, 2010 11:20 AM
Speed racer
Oct 11, 2008 10:56 PM
