Sponsored by: CARiD
need help brown sludge in radiator
Old Jun 17, 2020 | 01:58 PM
Dylan Hill's Avatar
Question need help brown sludge in radiator
i have a land rover disco 2 2000 and has been driving fine i opened my radiator cap to see brown sludge so i flushed it and ran water through the system a few times for about a hour then put radiator flush in it and let it run for about a week with the radiator flush then flushed it again which seemed to get most of it out checking again today and see brown sludge back in the radiator cap it doesnt overheat stay in the middle never gets hot and runs fine just cant get rid of it does seem as though it uses oil alot which it may be that but wouldnt know what causes that
Old Jun 17, 2020 | 02:23 PM
Sixpack577's Avatar
The coolant was probably never changed before and the radiator and/or heater core still have gunk in them.
And, if it's "using oil"; does the engine have any oil leaks?
It's a D2, it kinda has to leak at some point, lol.
Old Jun 17, 2020 | 03:53 PM
Dylan Hill's Avatar
ok thank you i pray thats the issue and yeah i smell oil occasionally while driving so there is probably a leak i would imagine havent ahd much time to check into it but i appreciate the help and hope thats the issue i havent had it for extremely long so im just finding kinks as i go
Old Jun 17, 2020 | 09:08 PM
DakotaTravler's Avatar
Oil usually causes a milky appearance.
If you want to REALLY clean the cooling system, you need to do a simple citric acid soak. Cheap, works well, doctor recommended.
https://www.bobistheoilguy.com/forum...e_Citric_Acid_
Old Jun 19, 2020 | 09:11 AM
WaltNYC's Avatar
could be that someone mixed dexcool (orange coolant) with the traditional green without doing a thorough flush in between.
fishEH
Aug 25, 2022 07:33 AM
flybd5
LR2
Nov 12, 2021 07:10 PM
Jason Feuerstein
Mar 9, 2020 07:52 PM
dougn
Oct 15, 2019 08:12 PM
Ursula
Aug 24, 2016 10:49 AM
