Sponsored by: CARiD
Need help with codes PLEASE HELP
Old Jul 22, 2011 | 06:04 PM
tarpon66's Avatar
Default Need help with codes PLEASE HELP
please help.. 03 discovery codes
p0103
p0150
p0327
p0159
p0139
check engine light came on... bad o2 sensor
replaced all o2 sensors
new alternator
new coil packs,plugs and wires
Replaced knock sensors
took it on an 80 mile run after clearing the codes..shut off the engine .. engine light came back on solid and rescanned .. came back with the above codes..
Please help, Respectfully,Mike
tarpon66@netzero.net
Old Jul 24, 2011 | 08:19 PM
P0103 Mass Air Flow Sensor High Out of Range Fault
P0150 Oxygen Sensor Cycle Fault *Codes* B U
P0327 Background Noise Low Fault Bank AP0159 Oxygen Sensor Slow Response *Codes* B D
P0139 Oxygen Sensor Slow Response *Codes* A D
A = Bank A of the engine. Cylinder #1 is located on Engine Bank A.
B = Bank B of the engine.
U = Upstream of the Catalytic Converter.
D = Downstream of the Catalytic Converter.
Found these at Land Rover OBD-II Trouble Codes. If you clean the MAF, be sure to use a product that is approved for use with CATs. MAFs can be very pricey, some over $1500 (my D1). New Discos have a lower price tag.
Old Jul 24, 2011 | 08:30 PM
What air filter have you been using, have you fixed the issue?
Old Jul 25, 2011 | 03:07 AM
tarpon66's Avatar
@ Savannah Buzz.... Thanks for the response... I guess I should have stated that I already knew what the codes were or better yet the description of each code.. the problem here is that I have replaced parts/ or addressed each code as they came through...it seems as I replaced a part and cleared the code..a new code would show up.. @ this point I have replaced all the above mentioned parts...and final result is the five codes are showing in the scan.. I'm at a loss as to what to do next.. I wonder if it may just be a computer issue at this point...PCM,ECU,ECM... also not sure what the difference is between the 3....
@ Disco Mike... Fram filter... and as you can see... Issue still to be resolved ...
Thanks for the input Guys...Cheers Mike
Old Jul 25, 2011 | 06:19 AM
One way might be to obtain an ECU (engine control unit) from a salvage yard. I paid I think $40 for mine, and it came with a 30 day warranty. If it fixes it, after re-learning all the vehicle sensors, great. If not, refund. You would want the same year model if possible. The U-pull-it style yards are great fun. My original ECU would not "learn" my new idle air control valve no matter what procedure I used.
Old Jul 27, 2011 | 12:38 PM
CFonk856's Avatar
good idea, very interesting
______________________________
http://derwan.my3gb.com/rover.htm
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
