Sponsored by: CARiD
Need help, odd idle, etc...
Old Nov 15, 2008 | 12:14 PM
rsm688's Avatar
Default Need help, odd idle, etc...
Well I had a really rough Idle, ran decent when in gear driving. I replaced the IACV stepper motor (with a grand cherokee one) and now my idle sits pretty smoothly around 750rpm (seems kinda low to me). Also, when I put it in drive and I dont touch the gas it will accelerate on its own, in a two hundred yard stretch I was doing about 20mph. Any idea what could cause this? I also noticed at idle it puffs a little bit of grey smoke.I cant really atest to whether or not it did this before because I recently got the vehicle so I dont know.Any help would be greatly appreciated...Btw, it is a 96 Disco 1 4.0 with 155k miles, 5kmiles/1 year since full head job on the engine.thanks,spencer[/align]
Old Nov 17, 2008 | 08:45 AM
Default RE: Need help, odd idle, etc...
Clean your t/body and check for a large vacuum leak which could be causing this idle problem.
Old Nov 17, 2008 | 08:44 PM
rsm688's Avatar
any specific areas to look for when looking for vaccum leaks? I sprayed carb cleaner around the butterfly valve where the intake hose attaches. Should I remove it from the vehicle completely and clean?
Thanks,
spencer
Old Nov 18, 2008 | 08:59 AM
No, just make sure you get all the black guh wiped out of the t/body.
As for leaks, check all hoses for crack, leaks or a spungy feeling. When the engine is COLD, start it and spray car cleaner around the entire intake manifold seal area, if the idle increases, you found your leak.
Old Nov 18, 2008 | 07:21 PM
rsm688's Avatar
thanks I will give that a shot and see what happens
ycc456
Dec 11, 2013 08:11 AM
achapman
Jun 25, 2013 03:40 PM
06Range
May 8, 2013 09:01 PM
TheBelly
Nov 1, 2010 08:34 PM
rsm688
Nov 17, 2008 08:54 PM
