Sponsored by: CARiD
need you guys help
Old May 24, 2009 | 07:31 PM
maaliq1215's Avatar
Default need you guys help
im new to the sit i have a 96 rover 4.0 i need to know how to check,drain,and refill my transfer case getting a loud winding gear sound when i drive it
Old Jun 6, 2009 | 02:58 AM
tedly797's Avatar
Hi,
There are 2 plugs on the rear of the t-box on the driver's side, one for drain and one for filling. They have a 1/2 square drive hole to use your 1/2 ratchet to open. They require dextron/mercon III for fluid, fill until it runs out of the fill hole
Old Jun 6, 2009 | 08:20 AM
Rover up graded their oil requirement to either a 75 to 90W gear oil or the 85/140W.
You might want to consider do a full service on this truck if it is new for you.
Also, check the magnetic drain plugs for chunks of metal and lube your drive shafts.
Old Jun 7, 2009 | 03:59 PM
tedly797's Avatar
Disco Mike is absolutley right about doing the full service on the rig especially if it is new to you.
I just checked on this because Mike had me wondering, as of today the t-box oil spec is still ATF dexron III ( From official website as of today for the p38 t-box ). I have seen people using gear oil and the fill plug definitley is big enough, but the spec is ATF. I have no experience to say to use gear oil, but i will say I have never had an issue with the spec fuild.
calebbo
Oct 12, 2011 09:54 PM
bothomasmusic
May 6, 2011 02:33 PM
Spencerfitch
May 9, 2010 11:30 PM
Dublz
Sep 9, 2007 07:05 PM
MRDM1
Mar 16, 2007 07:03 PM
