Sponsored by: CARiD
No brake lights, diff cld warning
Old Mar 14, 2016 | 11:15 PM
Sarahcake's Avatar
Default No brake lights, diff cld warning
So I left california a week ago, and I've finally made it to Tennessee. I've only got 17 more hours to go before I reach my new home! the morning we left, I plugged up my trailer to my 01 disco se7 and away we went. It was about 4:30 am and we were traveling down the I-5, I tapped the brakes and saw my diff light come on. I radioed back to my partner and asked if my brakes were on and she said no. We stopped to refuel and I couldn't get it into drive again, and panic ensued. I remembered there was a neutral safety bypass and I popped up the shifter and got it into drive, which I've been doing for about a week. We got to Arkansas a few days later and i replaced the brake light fuse and voila brake lights work, it shifts out of park, and I'm happy as a clam. Well, I drove it a few miles down to refuel again, and the fuse blows! Whats happening? Should I buy a new brake light switch? Should I change out all the bulbs? I tied my trailer harness into the stock harness under the pass tail light. The fuse blows even when the harnesses taken out of the equation. Where should I start looking?
Old Mar 15, 2016 | 08:24 AM
wjsj69's Avatar
I had a similar problem, except my brake fuse would only blow when I engaged the diff-lock and as soon as I hit the brakes. I took the shift solenoid out so it wouldn't lock me out again, and kept spare fuses in the truck. I also replaced the brake switch and all rear bulbs with no change. Then it just kind of went away, it hasn't happened in a while, and I never figured out what it was.. So, if anyone has any suggestions, I would also appreciate it.
Old Mar 16, 2016 | 08:09 AM
Sarahcake's Avatar
Ive used the search function here and looked at the other posts. Thats how I figured out where the brake fuse was, and also the stock trailer plug-in. The other posts I've found, i exhausted their replys (replies) and other than just continuing to replace that fuse, what else should I do? Check a relay ?
Old Mar 16, 2016 | 08:34 AM
wjsj69's Avatar
Oh yeah, I also got an auto-reset circuit breaker to put in place of the fuse, so if it ever happens again, I don't have to keep replacing the fuse. ..obviously not a permanent fix, but should get you out of a jam until you figure it out..
Attached Thumbnails No brake lights, diff cld warning-51sf3yhxlul._ac_ul320_sr238-320_.jpg
Old Mar 22, 2016 | 01:19 PM
sleepercoupe's Avatar
Check the ground wire going from the driver side tail light harness (through the body) to the chassis ground behind the plastic panel in the cargo area.
Old Apr 6, 2016 | 10:49 AM
Sarahcake's Avatar
Alright! So the past few weeks I've been using my rear foglights as temp brake lights just to scoot around town. I took the driver side rear taillight out and saw some wires spliced into the stock harness, I traced them to a UHaul trailer harness that didn't work. I cut that out, replaced the fuse, and wouldn't you know it, my brake lights work! Un believable! I'm happier than a Democrat on election day!
Old Apr 6, 2016 | 12:17 PM
Congrats! Glad I was able to sort of help.
Sarahcake
Mar 14, 2016 11:10 PM
bullcrew
Jan 11, 2012 12:10 PM
FightOnUSC79
Sep 14, 2010 11:27 AM
FightOnUSC79
Jul 21, 2010 11:02 PM
ajh
Sep 17, 2006 02:36 AM
