Sponsored by: CARiD
No spark, has fuel, please help!!
Old May 3, 2010 | 06:32 PM
musickjr's Avatar
It has been about two years on the plugs and wires. I used Bosch plugs, and not sure what cables.
All I was saying is that up until the day it stopped running, it showed no signs of any problems.
How do you reset the codes were done the day I posted on the forum. Nothing has changes since then.
What are the codes stating?
Old May 3, 2010 | 06:50 PM
hilltoppersx's Avatar
the point is, according to you, you are getting fuel but not spark. so we are trying to figure out why there is no spark. your codes are all misfires which are commonly caused by bad plugs and/or wires.
1313 - Misfire Catalyst Damage Fault Bank A
1314 - Misfire Catalyst Damage Fault Bank B
1316 - Misfire Excessive Emissions Fault
0305b - Misfire Cylinder 5
0307 - Misfire Cylinder 7
0308 - Misfire Cylinder 8
0300b - Misfire On Multiple Cylinder
Old May 3, 2010 | 06:59 PM
musickjr's Avatar
Replaced the plugs And wires about two years ago. Bosch plugs not sure about the wire name. The codes are from a few days ago.
Old May 4, 2010 | 05:36 AM
musickjr's Avatar
I will go ahead and replace the plugs and wires. Any brand preferance out there?
Old May 4, 2010 | 09:25 AM
i prefer magnecor 8mm wires from apexperformance.net and bosch +4 plugs from Amazon.com
Old May 5, 2010 | 06:21 AM
Rovin4life's Avatar
five bucks says it aint the plugs and wires but the ecu or the coil itself. alot of times the ecu itself craps out causing misfires and the lot. you can get an used ecu for a disco one and then have the security programmed by a dealer or someone with testbook.
Old May 9, 2010 | 06:19 PM
musickjr's Avatar
ok so when I bought the plugs they had a sale on scnners and I bought one. I ran the scanner and then cleared the codes. The disco started after that. now it cranks when I start it, but it is now just giving me the p032 code. i have not replaced the plugs or wires yet.
any clues whats up?
thanks for all your responses so far
sdhow
Dec 23, 2014 11:08 AM
Motorvated
Aug 5, 2013 12:45 PM
ADDAM
Mar 10, 2012 12:26 PM
sawadeh
Jul 2, 2011 08:10 PM
johndavidrichards
Jun 17, 2011 09:26 PM
