Sponsored by: CARiD
Nomanclature help
Old Sep 22, 2010 | 12:53 PM
lostjohn's Avatar
Default Nomanclature help
I need to replace the bushings in the lower suspension links, but shopping for the parts online, I am not entirely sure the correct naming.
The front bushings are clear, they have a distinctive shape, but the rears I am not completely sure.
Yeah I know, when I pull one then I know, but I'd like to have the parts onhand before I start disassembly.
98 Disco 176K
Old Sep 24, 2010 | 06:27 AM
Rovin4life's Avatar
atlantic british has sets of them and individual
Old Sep 24, 2010 | 06:42 AM
antichrist's Avatar
I'd just get the kit, probably all need replacing if they are original, with that many years and miles.
Odds are you also need the upper A-Arm ball joint as well.
Old Sep 25, 2010 | 02:42 AM
lostjohn's Avatar
Thanks guys
worked fingers before brain. I checked all other bushes, looks like everything else is tight and not degraded.
Found the bushes I needed on AB, along with the coil set.
I find it a bit strange the OBD tells the shop I have a coil bad, but do running problems. I'm going to replace em all and assume the computer is picking up a voltage irregularity prior to a complete failure.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
