Sponsored by: CARiD
Non starting D2
Old Jul 19, 2016 | 03:40 PM
jason.boyd57's Avatar
6th Gear
Default Non starting D2
I recently purchased an 03 D2. When I purchased it the truck did not run. The previous owner had the ignition switch changed(may need it again). Looking for advice on were to start troubleshooting. When the key is turned the dash lights come on, the windows and seats work, but the engine does not turn over. Not a click or anything. The battery is good I used it for a trip to the Keys. I am suspicious of some sort of engine immobilizer. Any help would be appreciated. J
Old Jul 19, 2016 | 04:34 PM
number9's Avatar
Do you have a working remote that locks/unlocks doors?
There's a red LED that should be flashing if the engine is immobilized.
Anti-theft status LED
A Light Emitting Diode (LED) situated in the instrument cluster indicates the condition of the anti-theft system and acts
as a warning to potential thieves that the alarm system is activated.
Input/Output
The LED has a dedicated signal from the BCU to indicate the status of the following:
l Alarm armed: The LED flashes at 10 Hz with a 50:50 duty cycle for 10 seconds, after which the LED flashes 50
ms on, 2 seconds off until the state of the system changes.
l Engine immobilised: If the engine is immobilised and the ignition is on, the LED is illuminated continuously. If the
engine is immobilised and the ignition is off, the LED flashes 50 ms on, 2 seconds off.
l Alarm tampered: If the alarm has been triggered, the LED flashes at 10 Hz with a 50:50 duty cycle.
l Handset battery low indicator: If the handset battery is low, the driver's door is open and the ignition is switched
off, the LED flashes two pulses of 50 ms on, 50 ms off, every 10 seconds.
Old Jul 20, 2016 | 06:42 AM
mollusc's Avatar
Did you check the 150A mega fuse or the fusible link for the starter motor?
Old Jul 20, 2016 | 09:46 AM
Racer X's Avatar
I would check all of the fuses, including the megafuses.
Old Jul 20, 2016 | 03:37 PM
6th Gear
There is no red light on the dash blinking. Thanks for the info. I don't have an owners manual so most things I am finding by accident. Thanks again for the insight. j
Old Jul 20, 2016 | 03:38 PM
6th Gear
I will start checking the fuses next. Thanks j
Old Jul 20, 2016 | 09:45 PM
number9's Avatar
The info came from a maint manual. if you download Rave manual, the large file with warning it includes all including Owner's in PDF format.
land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
Mountainmotors
Freelander
Jul 28, 2011 03:44 AM
patrickc2010
Freelander
Nov 11, 2010 02:51 AM
Wildwolf498
Nov 27, 2008 01:22 PM
provinggrounds
Jul 22, 2007 10:42 PM
