Non starting D2
I recently purchased an 03 D2. When I purchased it the truck did not run. The previous owner had the ignition switch changed(may need it again). Looking for advice on were to start troubleshooting. When the key is turned the dash lights come on, the windows and seats work, but the engine does not turn over. Not a click or anything. The battery is good I used it for a trip to the Keys. I am suspicious of some sort of engine immobilizer. Any help would be appreciated. J
There's a red LED that should be flashing if the engine is immobilized.
Anti-theft status LED
A Light Emitting Diode (LED) situated in the instrument cluster indicates the condition of the anti-theft system and acts
as a warning to potential thieves that the alarm system is activated.
Input/Output
The LED has a dedicated signal from the BCU to indicate the status of the following:
l Alarm armed: The LED flashes at 10 Hz with a 50:50 duty cycle for 10 seconds, after which the LED flashes 50
ms on, 2 seconds off until the state of the system changes.
l Engine immobilised: If the engine is immobilised and the ignition is on, the LED is illuminated continuously. If the
engine is immobilised and the ignition is off, the LED flashes 50 ms on, 2 seconds off.
l Alarm tampered: If the alarm has been triggered, the LED flashes at 10 Hz with a 50:50 duty cycle.
l Handset battery low indicator: If the handset battery is low, the driver's door is open and the ignition is switched
off, the LED flashes two pulses of 50 ms on, 50 ms off, every 10 seconds.
Input/Output
I don't have an owners manual so most things I am finding by accident.
land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
Wildwolf498
Nov 27, 2008 01:22 PM
