Sponsored by: CARiD
O2 sensor voltage acting odd
Old Nov 7, 2012 | 12:45 PM
willys_49's Avatar
5th Gear
Question O2 sensor voltage acting odd
Long story short I replaced the upstream o2 sensors (2). B1 s1 no voltage at all, b2 s1 works fine at idle (.995-1.015) but when I push down accelerator the voltage drops to 0.000. Both s2's are working fine. I suspect that b1 s1 has a short in the wiring? But is it possible this is a computer issue? Thanks
Old Nov 7, 2012 | 12:50 PM
I'll vote for wiring and maybe a ground issue.
Old Nov 11, 2012 | 02:04 PM
willys_49's Avatar
5th Gear
I rewired the the whole o2 loom with a salvaged harness and now have started getting normal voltage readings. Although at times the readings seem a bit low on upstream, is this due to the ecu having to find new parameters?
Richard.rover
Jan 17, 2022 03:49 PM
LRD2&ME
Jan 25, 2015 01:58 PM
tomrover
Jul 23, 2014 08:14 PM
LRD2&ME
Jul 8, 2011 07:16 PM
vjm530
Jul 7, 2008 08:19 PM
