Sponsored by: CARiD
O2 sensors
Old Oct 15, 2011 | 07:08 AM
antichrist's Avatar
Originally Posted by Chris-bob
So it sounds like a reasonable price from a shop....
I didn't say it was unreasonable.
Depends on labor rates where he lives.
I have no idea what common labor rates are for garages.
Old Oct 16, 2011 | 01:48 PM
dpdelosreyes's Avatar
4th Gear
Thanks for all the tip guys! I was thinking of buying the parts myself and just have the guy install it. What would be a good brand with a reasonable price? I saw Denso for like $60 each. Will that work out just fine? Thanks again...
Old Oct 16, 2011 | 06:01 PM
Go to Amazon.com and buy them there, NTK are about $45 each, in my link I posted in your thread I believe is a link to the ones I bought, all DI's with OBDII use the same O2's.
Old Oct 17, 2011 | 12:32 PM
Chris-bob's Avatar
Wasn't implying that you did, just stating that for a shop, it sounds like a reasonable price. I am also out of touch with shop labor rates. We have virtually zero competition here, so the various shops all charge $100/hr. In the lower 48, you should be able to find lower shop rates than that if you can't/won't do the work yourself. I recommend doing it yourself and using the money for additional repairs that may be needed.
Old Nov 10, 2011 | 08:19 PM
4th Gear
I decided to give it a shot myself. Borrowed an OBD and code said P1316 - Misfire Excessive Emissions Fault. Does that mean the O2 Sensors are fine and it's more like the ignition wires and plugs? What should I replace first?
Thank you in advance everyone...
Old Nov 10, 2011 | 08:30 PM
Yes, that is exactly what it means, your O2's are fine and you need a tune up.
Like I said, 98% of O2 codes on a Rover are because it needs a tune up.
Old Nov 10, 2011 | 08:56 PM
Wrong, the late 97's and newer use a different 02 sensor for the advanced evap system. Need to verify which you need based on your vin.
Old Nov 11, 2011 | 07:01 PM
Thank you for the correction Mike.
ITMagician
Sep 20, 2015 08:47 PM
jsyonker
Sep 4, 2011 06:01 PM
Corsair33
Sep 18, 2006 10:15 PM
riebs
Aug 21, 2006 11:48 AM
JRdisco1
Aug 9, 2005 03:33 PM
