Sponsored by: CARiD
O2 system still not ready.
Old Jul 19, 2014 | 08:03 AM
dusty1's Avatar
Default O2 system still not ready.
Changed all 4 sensors about 1500 - 1800 miles ago. I had no codes then, but I had the top end off for hg....figured easy access.
Battery has not been disconnected since....
I go to get inspected (several times) I am told o2 and cat system not ready. Am I missing something? An issue would show code fosho? 3-400 miles maybe, but at nearly 2k I have to think something is amiss.
Any ideas?
Old Jul 20, 2014 | 10:04 AM
abran's Avatar
Are there any pending codes on the UG? I've read that could be it, You have definitely put enough miles on it, but I'm wondering if there isn't some part of the drive cycle missing?
I know there is a drive cycle for readiness. I found this one for Toyotas...
http://forum.ih8mud.com/attachments/di-70-1996-fsm-pdf.673704/
Someone on another forum said this worked for their LR4
Start engine, let idle for approx. 2 min, 10 secs.
Accelerate to 20-30 MPH, Maintain steady speed for approx 3 min, 15 secs.
Accelerate to 40-60 MPH, Maintain steady speed for approx 15 mins.
Decelerate and come to a stop. Then:
Idle in Neutral for 5 mins. (manual trans.)
Idle in Drive for 5 mins. (Tiptronic trans.)
During the drive cycle, do not exceed 3,000 rpm or 60 mph.
This is the "BMW" drive cycle, but it works equally well on 993's and if done properly does not require a second drive cycle.
Old Jul 20, 2014 | 12:36 PM
dusty1's Avatar
Cool. I'll give it a go.
No pending
Old Jul 21, 2014 | 09:33 AM
drowssap's Avatar
have you tried read your codes with something other than the ultra gauge?
Old Jul 21, 2014 | 09:48 AM
dusty1's Avatar
yes, at inspection place and with a couple of readers that I have.. just says o2 and cat system not ready. no pending
Old Jul 21, 2014 | 10:16 AM
drowssap's Avatar
just wondering if ultra gauge did not pick it up but a real OBDII scanner does, and it appears so.
I assume you have already cleaned and re-made all your 02 connections with dielectric grease and all that obvious stuff.
do you get readings from all of them on the OBDII scanner?
Old Jul 21, 2014 | 10:18 AM
dusty1's Avatar
yep all cleaned, lubed and tight. I use that little scangauge II.
if my cats were bad, I would get codes for rear o2s, correct?
Old Jul 21, 2014 | 11:43 AM
drowssap's Avatar
i would think you would get codes of the rear 02's, if it were a cat problem.
Old Jul 29, 2014 | 11:05 AM
dusty1's Avatar
Well I did a scan this morning. Looking for the "system not ready" display. It's still there,but I also have some pendies. Never showed before now. Still, though, it could be keeping me in not ready mode......I guess
P1172 & p1175
So I'm getting unmetered air. Has to be post maf, correct?
Leaves me with bad maf.....solution = I have a brand new Bosch in the spares
Or vacuum leak.....find it fix it. But I have a question. Could it be a leak at injector seal, also?
pwaltrip
Aug 14, 2012 02:57 PM
Maytag
Jul 10, 2012 11:03 PM
adigerol77
Jul 16, 2011 09:11 PM
iownme
Jan 13, 2011 03:34 PM
camper
Jan 12, 2011 09:19 PM
