Sponsored by: CARiD
OBD -With 2 ECT sensors, which one is sensor 2?
Old Jan 16, 2023 | 11:31 AM
malibumike's Avatar
Default OBD -With 2 ECT sensors, which one is sensor 2?
I have a 2011 LR4 and just got a P2183 engine coolant sensor fault high sensor 2. I think there is one sensor built in to the rear crossover pipe and one more near the thermostat. Live data shows coolant temp at 176 degrees at idle on a cool day Does a fault on sensor two indicate which sensor is having the issue? I have two LR4 so I may just swap the front ones and see if the code jumps to the other car.
Also, which affordable scanner would show live data for both sensors? This was one borrowed from Oreilys.
journeyman
Nov 20, 2023 04:13 PM
MMO
Dec 1, 2021 02:19 AM
neuropathy
May 2, 2021 08:05 AM
Enrique5
Jul 2, 2012 10:22 PM
workinghard1713
Apr 16, 2012 11:25 AM
