Sponsored by: CARiD
an odd set of issues
Old May 22, 2009 | 12:47 AM
Mountain_Ox's Avatar
Default an odd set of issues
my 92 rover is idling rather high and is running very rich. it is making alot of soot. when you give it any throttle. i just replaced the ICM on it could that be a factor. the timing is correct. the timing also dosn't seem to be affecting this. weather i advance or retard the timing. an it was running fine after i replaced the icm. it just started this little tantrum today.
my rover has the 3.9l v8 .
Old May 22, 2009 | 11:50 AM
i also have to press on the gas pedal a bit when starting it today. an it takes a few cranks to start . alot more than usual.
Old May 27, 2009 | 02:43 AM
klasds's Avatar
my 92 rover is Bike Trials idling rather high and is running very rich. it is making alot of soot. when you give it any throttle. i just replaced Bike Trial Seller the ICM on it could that be Bike Store a factor. the timing is correct. the timing also dosn't seem to Bike Shop be affecting this. weather i advance or retard the timing. an it was running fine after i replaced the icm. it just started this little tantrum today.
Old Jun 4, 2009 | 02:56 AM
tedly797's Avatar
No fault codes?
Check fuel pressure, mafs connector, o2 sensors,
Old Jun 5, 2009 | 02:23 AM
Originally Posted by tedly797
No fault codes?
hey thanks for your input. but my rover will have to wait i leave for alsaka monady an i will have to be leaving my rover home this time. i will have to fix it when i get back. any how. every one ttyl . till december.
Joshua
bagocheetohs
Aug 11, 2015 06:13 PM
nick731
Nov 16, 2010 12:25 PM
stripplerluva
Feb 14, 2008 08:04 AM
diego rover
Nov 7, 2007 04:22 PM
