Sponsored by: CARiD
Oil Changing
Old Jun 11, 2006 | 09:05 AM
T3LU_03's Avatar
8th Gear
Default RE: Oil Changing
ORIGINAL: Landzu
ORIGINAL: Landzu
SII Reset Procedure
1. Ensure that the ignition is switched off.
2. Press and hold the LH instrument pack button.
3. With the button held, switch the ignition on to position I (AUX).
4. Continue to hold the LH instrument pack button for a further 5 seconds,
until the "SIA RESET" appears.
5. The message centre will display the distance to service status as "RESET SIA: 3600km/mls"
and "INSPECTION".
6. Press and hold the LH button for another 5 seconds. 'RESET" flashes in the message center.
1.If the LH button is not pressed again before the fifth flash of "RESET",
the reset will not be performed.
The message center will display the existing distance to service data for 5 seconds,
followed by "END SIA" for 2 seconds, and then switch off.
2. If the LH button is pressed before the fifth flash of "RESET", the service distance will be reset.
The message center will display the new service distance " END SIA: 25000km/miles" for 5
seconds, followed by "END SIA" for 2 seconds, and then switch off.
7. Then switch the ignition off.
After a reset the SII cannot be reset again until the instrument pack registers the vehicle has used
20% of the fuel required to travel the normal distance to the next service.
Fuel required to travel the distance is stored in the instrument pack EEPROM,
and varies with engine type.
The V8 is 1075 U.S. gallons or 4075 liters fora normal distance of 15635 miles or 25000 kms.
I hope this helps.
Mike
I thought it may have been the right info it is.
DAmn, you are the man. The only one who know in this forum!!!
Old Jun 11, 2006 | 04:14 PM
Landzu's Avatar
Thanks, I just try to help.
Mike
Old Jun 11, 2008 | 06:21 PM
loulove's Avatar
I HAVE A 2006 RANGE ROVER AND I NEED SOME HELP RESETING OIL SERVICE MESSAGE CAN ANY BODY HELP ME PLEASE?
Old Jun 11, 2008 | 06:25 PM
loulove's Avatar
CAN ANYBODY HELP ME PLEASE? I HAVE A 2006 RANGE ROVER AND I CANNOT RESET OIL SERVICE MESSAGE I HAVE CHANGE THE OIL BUT I JUST CANT GET DONE.SOMEBODY HELP ME PLEASE.
Old Jun 11, 2008 | 07:07 PM
roverguy7's Avatar
you need the dealer for 06-08
Chrisinhouston
Dec 13, 2007 05:59 PM
khandrh
Aug 9, 2007 09:59 PM
bravesfan3b
Jul 16, 2007 10:23 PM
winnegar
Sep 19, 2005 09:35 AM
