Oil and Temp Gauges
Oil and Temp Gauges
Hey guys, looking to put in some new gauges on my 00 Disco. I have new autometer electric full sweep gauges from one of my other car builds and needed to see where the best place would be to put in the oil sending unit and temp sensor. I know there is a plate that goes on where the filter does for the oil sensor but i was kinda hoping to avoid that. I like placing the sensors either in a direct oil line or on the engine block itself. Also, are there any good pillar pods or dash pods i can use to mount them?
I went with the sandwich plate from glowshift. Figured by the time i rounded up all the tidbits (dont have any sort of that stuff laying around) i would end up spending the same amount.
Non sandwich setup
Oil gauge - LAND ROVER CLUB V.I.
Probably the best installation for gauges:
Installed New Gauges - Land Rover Forums : Land Rover and Range Rover Forum
Mine i put on-top of the steering wheel. Post #421
https://landroverforums.com/forum/di...-52339/page43/
Glowshift plate ~ $37 - this one has 4 ports, 2 for an oil cooler if you wish and 2 for oil temp and pressure...you can get one with just 2 ports also, think the price is about the same.
Oil Cooler Sandwich Adapter
Non sandwich setup
