Sponsored by: CARiD
P0304 Code/Misfire Won't Go Away
Old Jan 23, 2008 | 05:01 PM
WhiteLRII's Avatar
Default RE: P0304 Code/Misfire Won't Go Away
ORIGINAL: Disco Mike
Time to do a compression test and or a leak down, you may have a chipped exhaust valve.
I will try to do a compression test asap. Does this sound like a blown head gasket?
Old Oct 25, 2008 | 02:45 PM
AZ03DISCO's Avatar
5th Gear
Hey WhiteLR,
Did you ever get this problem solved? I have the same problem. I changed the lugs and wires. I think it might be the coil pack. If it was the coil pack, did you change it yourself? How much did it cost?
Any info is appreciated.
Dan
Old Oct 25, 2008 | 02:47 PM
AZ03DISCO's Avatar
5th Gear
Correction: I change the plugs, not the lugs. I don't think changing the lugs would help this issue.
Old Oct 25, 2008 | 04:01 PM
So what wires and plugs, how many miles on the truck?
Old Oct 25, 2008 | 11:32 PM
AZ03DISCO's Avatar
5th Gear
Wires: STI (Spark Transfer Internation). I had to order them from BAP. They were the most expensive ones they had (2 choices).
Plugs: NGK
Mileage: about 75k
The reason I changed the plugs and wires was because of the problem I'm having now so I doubt the new stuff is causing the problem, but it's not fixing it either.
One more thing. When I changed the #4 sparkplug (the cylinder that now misfires), the top of spark plug looked corroded like an old battery terminal. It was quite possibly not getting a good connection to the wire. I wonder if that can do damage to the coil pack.
Dan
Old Nov 19, 2008 | 10:35 PM
AZ03DISCO's Avatar
5th Gear
Nevermind. It was the coil. I just took it to the shop. I got it changed for $800. The disco runs fine... For now.
Old Nov 20, 2008 | 08:02 AM
Dam they sure stung you, the new coil packs sold at Rover Connection are only $270. I would sure want to know why they over charged you if that had happened to me.
MechMac
Jun 17, 2013 09:19 AM
hatt53
Mar 27, 2013 05:16 PM
prroverguy
Mar 20, 2013 07:04 PM
FLDISCO
Nov 18, 2011 07:53 AM
husker6:33
Jul 8, 2008 08:30 PM
